ProjeQtOr free project management software - [SOLVED] Wiping project - ProjeQtOr
18 Oct 2019 14:08 #1 by jmmbb
Wiping project was created by jmmbb
Hello (again :) ),
is it possible to give administrator the opportunity of "wipping" an entire project.
ie : if you want to delete project, you need to delete all dependancies before and it is sometime complex.
This function offer to admiistrator the opportunity of deleting projet and every linked elements (such as assignment, tasks, questions, milestone, documents, and even real work).
It will be a good extension of closing project because sometime we got a large amount of closed projects in database and sometime you need to clean up an instance.
18 Oct 2019 14:26 #2 by babynus
Replied by babynus on topic Wiping project
You can if the project does not have real work entered.
Just give admin the "can force delete" specific right.
It is not possible to delete project with real work, and I think it will never be possible : it would go against main design of Projeqtor consolidations.
Possibly we could give some opportunity to "clean real work" for some old projects, but there may be several restrictions (work that has been billed, validated weeks, ...)
18 Oct 2019 14:40 #3 by jmmbb
Replied by jmmbb on topic Wiping project
Thanks,
it works.
You're right, wipping project with real work will be aesy but not according of ProjeQtor's behavior. If you set real work, it show that someone as worked in it... So why erasing this without checking each impuations individualy ?
False good idea i think...
