ProjeQtOr free project management software - after installation: admin passwort doesn't work - Page 2 - ProjeQtOr
04 May 2019 14:38 #7 by babynus
It's not a mysql password issue.
Have a look at your DB : you should have a bit more than 200 tables.
So connection to db is fine.
After migration, try and clear browser cache, including cookies, or try and connect with another browser.
05 May 2019 16:55 #8 by ecky83
hi,
of course i tried also this.. just right now i recreated the folder and exaxtly how downloaded and created a new database called projeqtor, with same user and a "stupid" password.. after upload i went to the installpage, put in all parameters (but i didn't change timezone and language, everything turned green and was saved.. then firefox took me to the login-page.. in this moment i opend edge - and tried to login with admin/admin -> the wheel truned for about 20 sec. then it disapeard, but the login windows remaind. so i made one more click to "ok" for login and it tells me again: "Invalid login parameters"
what do i do wrong?? i use a virtual web server with ubuntu 14.x on it and plesk as management software.. are there maybe any known issues`?
regards, Ecky
05 May 2019 17:54 #9 by babynus
Please check for errors in projeqtor log file (at location you defined in configuration screen).
Post here any error.
Also look for errors in browser console.
05 May 2019 19:15 #10 by ecky83
oh.. quite a lot of errors..
05 May 2019 22:56 #11 by babynus
Migration was not complete.
It stopped during script for V1.7.0, after 2mn.
I guess you will find a "timeout" in Apache error log file.
Try and increase max_execution_time in php.ini (try and set to very big value such as 6000, which represents 100 minutes)
Restart Apache/PHP and retry deployment from scratch.
It should complete after a long time.
The main issue is that your server is very slow.
In all cases I met, migration was complete before 2min (on my laptop it takes less than 30s, on my servers, it takes 15 seconds max)
