ProjeQtOr free project management software - [SOLVED] Risk management, Opportunity management, display in reports - ProjeQtOr
02 May 2019 17:48 #1 by bvd
Maybe I am not using the module as it should, but I am not able to see all actions in the reports (risk management, and opportunities).
If I select a project, I get just One action in the report instead of the 27 actions actually opened. If iI select another project, I got 0 actions instead of the 17 opened.
What is the correct use of the report module ? Should I see all the actions in the report or juste some actions with criteria ?
03 May 2019 09:55 #2 by alainforma
You are right. I reproduced part of this anomaly. We correct this issue as soon as possible.
Regards.
03 May 2019 10:02 #3 by bvd
Thank you,
I will stand by :-)
03 May 2019 10:04 - 03 May 2019 10:05 #4 by bvd
Maybe this problem is linked with another one : when trying to access automated reports for user menu, I get an error : "Undefined variable : listedUser in AutoSendReport.php at line 272.
Last edit: 03 May 2019 10:05 by bvd.
03 May 2019 14:45 #5 by babynus
In Risk Management Plan you will see only actions that are linked to a risk or to an opportunity or to an issue.
All actions are not linked to Risks Management Plan (you can for instance have Meeting actions)
03 May 2019 14:52 #6 by babynus
Issur you face has no link with Risk Management Plan.
This issue appears because Visibility restriction of current user (limited to same organization or same team or else) does not allow him to see users, not even himself.
This issue will be fixed on next patch.
