ProjeQtOr free project management software - Screen Customization vs project display issue - ProjeQtOr
03 Apr 2019 15:03 #1 by karl.binet
Projeqtor V7.4.3
Screen Customization Plugin V5.3
First when i go to Screen Customization Plugin and select project i get this message. Is there a place where i can see what was fix automaticly (log file)
And i think that in the Project windows i'm having a display issue, things are not at the right place. Probably related to the error i'm getting in Screen Customization Plugin.
Any idea how to fix that ?
Regars
08 Apr 2019 20:54 #2 by babynus
Some issues are not fixed as expected.
Check order of fields in /model/custom/Project.php, compared to model/ProjectMain.php
Order should be the same (expect the ones you moved yourself)
