ProjeQtOr free project management software - [SOLVED] WBS errors - ProjeQtOr
[SOLVED] WBS errors
28 Feb 2019 09:56 #1 by UnluckyDuck
WBS errors was created by UnluckyDuck
I have a huge problem with WBS sequences since the update to 7.4.2.
I attach a screenshot to illustrate my problem.
All projects are impacted by the problem.
We found a workaround that dates back to 2017, which consists in placing an impacted project under another project, then pulling it out to force the recalculation of the WBS.
04 Mar 2019 18:09 #2 by babynus
Replied by babynus on topic WBS errors
V7.4.2 is able to fix the unconsitency.
In fact, issue is not due to V7.4.2, biut this version correctly checks unconsistency...
05 Mar 2019 11:23 #3 by UnluckyDuck
Replied by UnluckyDuck on topic WBS errors
Hi Babynus, thank you for your answer.
Is there any step or action to avoid in order to avoid this problem ?
05 Mar 2019 12:26 #4 by babynus
Most issues happened befor V7.4.2, as this patch version is more stable about WBS.
But we just discovered new issue when some activities are closed in the level you move items.
This should be fixed on next patch
The following user(s) said Thank You: UnluckyDuck
