ProjeQtOr free project management software - Timesheet export - ProjeQtOr
Timesheet export
19 Feb 2019 21:44 #1 by karl.binet
Timesheet export was created by karl.binet
V7.3.3
When i export a time sheet with the following settings, output is empty
Period to export: -- Selected Week
Resource to export -- Selected resource All resource does not work either
Selected month, year and get all are working fine
thanks
20 Feb 2019 10:26 #2 by babynus
Replied by babynus on topic Timesheet export
Please post error traced in log file
20 Feb 2019 10:29 #3 by babynus
Seems to work fine on V7.3.5 ;)
21 Feb 2019 13:17 #4 by karl.binet
Replied by karl.binet on topic Timesheet export
Hi
Upgraded to V7.3.5
same issue
no error in log file
2019-02-21 04:03:17.899 ===== TRACE ===== NEW CONNECTED USER 'marco.rivalti' (using remember me feature)
2019-02-21 04:12:53.021 ===== TRACE ===== DISCONNECTED USER 'marco.rivalti'
2019-02-21 07:02:38.928 ===== TRACE ===== DISCONNECTED USER 'gpizzuco'
2019-02-21 07:02:42.404 ===== TRACE ===== DISCONNECTED USER 'karl.binet'
2019-02-21 07:02:47.839 ===== TRACE ===== DISCONNECTED USER 'ahoac'
2019-02-21 07:04:19.527 ===== TRACE ===== Login of non admin user during upgrade. User 'cboivin'
2019-02-21 07:04:35.857 ===== TRACE =====
2019-02-21 07:04:35.857 ===== TRACE ===== =====================================
2019-02-21 07:04:35.857 ===== TRACE ===== DataBase actual Version = V7.3.3
2019-02-21 07:04:35.857 ===== TRACE ===== ProjeQtOr actual Version = V7.3.5
2019-02-21 07:04:36.024 ===== TRACE ===== =====================================
2019-02-21 07:04:36.024 ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V7.3.5
2019-02-21 07:04:36.034 ===== TRACE ===== === SCREEN CUSTOMIZATION ISSUE =====================================
2019-02-21 07:04:36.034 ===== TRACE ===== Certaines customisations d'écran ne sont pas cohérentes :
2019-02-21 07:04:36.034 ===== TRACE ===== - Projet
2019-02-21 07:04:36.037 ===== TRACE ===== Les customisations ont été corrigées automatiquement
2019-02-21 07:04:42.356 ===== TRACE ===== NEW CONNECTED USER 'karl.binet'
2019-02-21 07:06:55.227 ===== TRACE ===== NEW CONNECTED USER 'nsleclerc'
2019-02-21 07:08:56.052 ===== TRACE ===== DISCONNECTED USER 'karl.binet'
2019-02-21 07:08:59.175 ===== TRACE ===== NEW CONNECTED USER 'cboivin'
2019-02-21 07:09:18.819 ===== TRACE ===== DISCONNECTED USER 'cboivin'
2019-02-21 07:09:23.897 ===== TRACE ===== NEW CONNECTED USER 'karl.binet'
2019-02-21 07:10:39.155 ===== TRACE ===== DISCONNECTED USER 'karl.binet'
2019-02-21 07:10:44.690 ===== TRACE ===== DISCONNECTED USER 'nsleclerc'
2019-02-21 07:12:18.017 ===== TRACE ===== NEW CONNECTED USER 'karl.binet'
21 Feb 2019 21:35 #5 by babynus
Are you sure you have something to Export ?
Only real work entered is exported, so no entry menas no export...
22 Feb 2019 14:15 - 22 Feb 2019 14:16 #6 by karl.binet
Hi, yes i'm sure, here is some more information
User Benoit Chauty
Week 7 from february 11 to 17
Timesheet
Here is the export for
Period = Selected months
resource = selected resource
Period = Selected week
If it can help you in your search, while writing this post, out of the blue, i ran an export for select weeks/selected user and it work 1 time.
So since i started this post, i may have tried about lets say, 25 time, i had only i time the export gave me results. i can't realy figure out why.
Last edit: 22 Feb 2019 14:16 by karl.binet.
