ProjeQtOr free project management software - Screen customization issue when upgrading to V7.3.3 - Page 2 - ProjeQtOr
17 Jan 2019 15:54 #7 by TLamy
File Attachment:
File Name: Project-Co...1-17.txt
File Size:7 KB
20 Jan 2019 14:07 #8 by babynus
Here is file fixed
The following user(s) said Thank You: TLamy
21 Jan 2019 09:28 #9 by TLamy
Hello! Thanks a lot!
I effectively recovered the screen customization for projects.
So it works as before, however I still have some errors but much less bothering.
When I click on a project I have this error in the log:
2019-01-21 09:14:02.616 ***** ERROR ***** [V7.3.3] Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'refId' in 'where clause'
2019-01-21 09:14:02.618 ***** ERROR ***** [V7.3.3] For query : select id from productproject where refId ='32' and refType ='ProjectMain' order by id desc
2019-01-21 09:14:02.620 ***** ERROR ***** [V7.3.3] Strack trace :
2019-01-21 09:14:02.621 ***** ERROR ***** [V7.3.3] #0 Sql->query called at [/projeqtor/model/persistence/SqlElement.php:2982]
2019-01-21 09:14:02.622 ***** ERROR ***** [V7.3.3] #1 SqlElement->getDependantSqlElements called at [/projeqtor/model/persistence/SqlElement.php:2857]
2019-01-21 09:14:02.623 ***** ERROR ***** [V7.3.3] #2 SqlElement->getSqlElement called at [/projeqtor/model/persistence/SqlElement.php:594]
2019-01-21 09:14:02.624 ***** ERROR ***** [V7.3.3] #3 SqlElement->__construct called at [/projeqtor/model/ProjectMain.php:176]
2019-01-21 09:14:02.625 ***** ERROR ***** [V7.3.3] #4 ProjectMain->__construct called at [/projeqtor/model/custom/Project.php:222]
2019-01-21 09:14:02.626 ***** ERROR ***** [V7.3.3] #5 Project->setAttributes called at [/projeqtor/view/objectDetail.php:562]
2019-01-21 09:14:02.627 ***** ERROR ***** [V7.3.3] #6 drawTableFromObject called at [/projeqtor/view/objectDetail.php:285]
In the screencustomization plugin if I try to globally hide the type restrictions section I got an error too:
2019-01-21 09:22:56.893 ***** ERROR ***** [V7.3.3] ERROR *****
2019-01-21 09:22:56.895 ***** ERROR ***** [V7.3.3] on file '/projeqtor/plugin/screenCustomization/screenCustomizationSaveField.php' at line (695)
2019-01-21 09:22:56.896 ***** ERROR ***** [V7.3.3] cause = Undefined offset: 1
However if I individually hide this type restrictions section for each profile (including administrator), there is no error.
Best regards
Thierry
22 Jan 2019 09:39 #10 by babynus
first issue (unknown column 'refId' in 'where clause') recorded as Ticket #3796
second is recorded as Ticket #3797, fixed, and will be deplouyed on next version of plugin.
NB : to hide the restrict type section, you may simply set Global Parameter "allow type restriction on project" to "NO"
23 Jan 2019 15:49 #11 by babynus
For information, version 5.3 of screen customization plugin is deployed
23 Jan 2019 15:55 #12 by TLamy
Thank you very much for your help !
Thierry
