ProjeQtOr free project management software - [SOLVED] Time Sheet -- Acitivy displayed under wrong project - ProjeQtOr
18 Dec 2018 17:11 #1 by karl.binet
Hi, here is the details, Note that i have this problem with other activities with other project.
Projeqtor version : 7.2.7
Projet ID: 4308
Project Name : Laurier du Vallon_Réaménagement succursale Laurier Québec
Attachment not found
Here is the list of all activities for this project
Activity ID 1451
Activity ID 1452
When i go into Time Sheet, these two activities are displayed under another project. They are displayed under project ID 4454 instead of project ID 4308
Can't figure out why ! is there an explanation ?
Can you help please ?
19 Dec 2018 13:57 #2 by Gautier
Can you post your logs file please.
19 Dec 2018 14:47 - 19 Dec 2018 14:48 #3 by karl.binet
hi Log files was added to attachments, note that i had the same issue before the update to 7.3.1
Last edit: 19 Dec 2018 14:48 by karl.binet.
19 Dec 2018 14:58 #4 by Gautier
Did you clean your browser cache ?
Can you try in administration screen to click on " scan for issues" then "fix issues"
19 Dec 2018 15:50 #5 by karl.binet
Scan then fix isssue solved my problem, didn't know about this tools, thanks for your help.
