ProjeQtOr free project management software - Invalid Login Parameters - ProjeQtOr
05 Dec 2018 12:20 #1 by emmanoueli
I spent 20 hours to setup your system with now result.
I have tried with 7.2.7 and 7.3.1 with XAMPP , all parameters in your check screen are green and OK.
I ve checked with phpMyadmin that the system has created the database projeqtor and the relevant tables.
The issue has to do with the 1st login attempt.
When i put user admin and password admin (as per your readme.txt file) the system responds with a red sign and the message "Invalid Login Parameters"
Bear in mind that my Apache has been configured to use port 8090 instead of 80 but this should not be an issue since ALL pages and other apps are working properly
Please advice
05 Dec 2018 16:01 - 05 Dec 2018 16:04 #2 by Damian.sd
Replied by Damian.sd on topic Invalid Login Parameters
It is probably connexion problem with DB check your parameters in files/config/parameters.php because if you change password to DB, you must change value in parameters.php.
Last edit: 05 Dec 2018 16:04 by Damian.sd.
05 Dec 2018 16:16 - 05 Dec 2018 18:31 #3 by babynus
Replied by babynus on topic Invalid Login Parameters
Try and clean browser cache and retry.
If problem persist, check browser console [F12] and post here any error logged.
Last edit: 05 Dec 2018 18:31 by babynus.
06 Dec 2018 13:39 #4 by emmanoueli
Replied by emmanoueli on topic Invalid Login Parameters
thank you for your answer however this is not the case since the password is blank and it is crosschecked
06 Dec 2018 13:54 #5 by emmanoueli
I have cleared the cache but the system persists. No error shown on browser.
What else can be done ?
Windows 10
Firefox, Chrome and Edge tested
Mariadb root has no password
Any idea ?
06 Dec 2018 14:28 #6 by babynus
Please check content db.
Do you have tables ?
Do you have table resource ?
Do you have line with id=1 and name='admin'
If so, try and execute :
update resource, set password='admin', crypto=null where id=1;
