ProjeQtOr free project management software - [SOLVED] Sort by priority will make pdf export from project list empty - ProjeQtOr
04 Dec 2018 14:56 #1 by 4ce
Hi there - if i'm trying to Export my Project list ordered by priority the created PDF is empty. Only a Header appears.
if i order by any other field, everything is ok. ordering by priority and the same behaviour will take place.
tested in Firefox and Internet Explorer.
the print Export is similar, so i can't use any PDF printing Software or anything else.
i guess this is a bug.
please check
04 Dec 2018 16:06 #2 by babynus
I cannot reproduce on V7.3.1.
Which version are you using ?
05 Dec 2018 08:07 #3 by 4ce
ok.
i'm using 7.2.5
I was waiting for a stable 7.3.x. Can you tell me when 7.3.x will be released stable?
05 Dec 2018 09:17 #4 by babynus
i'm using 7.2.5
You'd better use latest patch of V7.2 (V7.2.7)
We're never sure, but V7.3 could be tagged stable on next patch (V7.3.2) in 8-15 days
05 Dec 2018 09:59 #5 by 4ce
thank you for your reply.
so first at all i just updated to 7.2.7 and the error appears again. just for my understanding, that we both understand the same thing, i tested on demo (7.3.1) and the same behaviour took place.
so i try to describe my problem again.
i'm trying to take a pdf out of the project list (overview) by odering the columns in priority (you exactly put priority in your overview). in demo modus, as on my system, appears the down attached screenshot (1). if i order by ID everything works fine (see attached screenshot from demo modus no. 2). ordering by priority i get an empty pdf (except the header, this is written corectly).
can you please recheck the issue or tell me what i might doing wrong?
05 Dec 2018 10:19 #6 by babynus
You right.
This issue occurs when :
- you sort by clicking on header of column
- projeqtor is on linux
I tested with sort using a filter (attribute = priority, operator = sort)
I also tested with click on coluln header, but on windows, where issue does not ossur.
Issue recorder as TIcket #3704.
