ProjeQtOr free project management software - Global project planning - ProjeQtOr
04 Dec 2018 11:26 #1 by LG_Teleflow
Since the last update to V3.0, the page that I like very much Global Project planning which shows all selected items is blank whatever the items I select, the page remains blank.
I switch back to the simple planning view.
Before the update, I was able to display each items correctly.
I will proceed to the update to V3.1 today, but not sure this will restore this function?
Best Regards,
Laurent
04 Dec 2018 11:49 #2 by Gautier
Replied by Gautier on topic Global project planning
Can you post your logs please.
Have you clean your browser cache ?
04 Dec 2018 11:52 #3 by LG_Teleflow
Replied by LG_Teleflow on topic Global project planning
Dear Gautier,
Thanks for your answer, I got cleared the cache and I also tried to change browser from Firefox to Chrome and got the same result.
Here is the log:
2018-12-04 11:27:44.260 ***** ERROR ***** [V7.3.0] Strack trace :
2018-12-04 11:27:44.260 ***** ERROR ***** [V7.3.0] #0 Sql->query called at [/var/www/html/tool/jsonPlanning.php:283]
2018-12-04 11:27:44.260 ***** ERROR ***** [V7.3.0] #1 include called at [/var/www/html/view/globalPlanningList.php:523]
2018-12-04 11:27:44.260 ***** ERROR ***** [V7.3.0] #2 include called at [/var/www/html/view/globalPlanningMain.php:57]
Thanks,
Laurent
04 Dec 2018 12:09 - 04 Dec 2018 12:10 #4 by Damian.sd
Replied by Damian.sd on topic Global project planning
Hello Laurent,
We cannot reproduce your problem, we need more information for that.
1) show us your complete log file.
2) show us your console log on mozilla with F12.
3) On Administration page run scan for issues and fix it.
4)Test to reproduce your problem on test.projeqtor.org and reply us your result.
Last edit: 04 Dec 2018 12:10 by Damian.sd.
04 Dec 2018 13:33 - 04 Dec 2018 13:34 #5 by babynus
Replied by babynus on topic Global project planning
This issue is fixed on V7.3.1
Last edit: 04 Dec 2018 13:34 by babynus.
04 Dec 2018 14:16 #6 by LG_Teleflow
Thanks all for your feedback, I'll proceed to the update as soon as possible and I'll keep you informed if the function is fixed as Babynus said!
