ProjeQtOr free project management software - [SOLVED] Project in definicit not editable - ProjeQtOr
21 Nov 2018 10:00 #1 by cnguyen
We can't understand why Project with negative cost margin can't be edited in any way.
When we try to change any field, saving is refused with the Alert popup :
"Some field contains invalid data.
Please correct first"
no field is underlined, we can't change anything. Is there a parameter that need a change to permit modification of those projects ?
KR.
21 Nov 2018 11:29 #2 by Gautier
This problem is solved #3551 in Projeqtor v7.2.2.
You should update our last stable Projeqtor if you want the correction..
21 Nov 2018 15:11 #3 by cnguyen
We are in projeqtor 7.2.6
Cyril
21 Nov 2018 15:33 - 21 Nov 2018 15:35 #4 by Gautier
I'm sorry bug fixed on V7.2.7, it is ticket #3643
Last edit: 21 Nov 2018 15:35 by Gautier.
21 Nov 2018 16:07 #5 by cnguyen
Ok, Thanks for the answer.
