ProjeQtOr free project management software - Error on first launch - ProjeQtOr
09 Nov 2018 14:37 #1 by Stas
Error on first launch was created by Stas
Good day! I installed on the server:
-Apache 2.3.37 Win64
-PHP 5.6.38
-MySQL 8
-projeqtorV7.2.7
The first time I run the configuration window, I get an encoding error as shown.
Please tell me how you can fix this problem.
12 Nov 2018 10:36 - 12 Nov 2018 10:38 #2 by babynus
Replied by babynus on topic Error on first launch
Your MySql servers required some authentication that is not provided by your parameters.
1) Check account parameters for MySql
2) Check in my.ini and in db that user defined above can access database
3) if your db requires SSL, try and define ssl parameters.
Last edit: 12 Nov 2018 10:38 by babynus.
12 Nov 2018 10:43 #3 by Stas
Replied by Stas on topic Error on first launch
Thank you very much for the answer. At the moment I fixed the issue when installing:
- Apache 2.4.37
- PHP 7.2.12
- MySQL 8
In MySQL server settings set the parameter: default_authentication_plugin=mysql_native_password
