ProjeQtOr free project management software - External Project Leader can not modify a ticket - ProjeQtOr
08 Nov 2018 08:09 - 08 Nov 2018 08:10 #1 by naceur.ayachi@tsi.com.tn
What we wanted to do :
- External Project Leader create Ticket
- Project Leader assign it
- Anyone make it in progress and then Done
- External Project leader makes it Closed : And here happens the problem
External Project Leader receives this error message : You tried and directly remove more than your own work (0 h). You should use "Dispatch work" button for this.
In fact since the ticket has received time spent on it external project leader can not modify anything on this ticket
This error message does not happen with internal users
Last edit: 08 Nov 2018 08:10 by naceur.ayachi@tsi.com.tn.
08 Nov 2018 08:15 #2 by babynus
Check work on ticket.
It seems External Project Leaders changed real work.
He cannot directly remove work that he did not enter himself.
08 Nov 2018 10:02 #3 by naceur.ayachi@tsi.com.tn
External Project Leader is not allowed to enter or modify any real work. (see attached print screen)
Other users (Internal) enter real work.
The problem happens since other users enter real work.
Before other users enter real work the external project leader can do everything correctly
The same problem happens with external project member
08 Nov 2018 14:06 - 08 Nov 2018 14:07 #4 by babynus
Ticket #3655 recorded for analyses
Please indicate which version of ProjeQtOr you are using
Last edit: 08 Nov 2018 14:07 by babynus.
09 Nov 2018 08:21 #5 by naceur.ayachi@tsi.com.tn
12 Nov 2018 16:17 #6 by babynus
This issue is fixed on V7.2.7
