ProjeQtOr free project management software - [SOLVED] screenCustomization V4.0 not accessible on V7.2.2 - ProjeQtOr
25 Sep 2018 11:27 #1 by QUANTAMEDICAL
No menu to acceed to screenCustomization functionnality
Please show screen on admin account
Thank's for help
25 Sep 2018 11:45 #2 by babynus
First , your should concider download and install latest version of plugin (V5.1)
Access to the "screen customization" plugin is managed through "accees to forms", like access to any other screen.
Check that profile of user has access to this screen
The following user(s) said Thank You: QUANTAMEDICAL
15 Oct 2018 11:22 #3 by QUANTAMEDICAL
I have updated this plugin but cannot access config interface
Please Check Version installed :
On accees to forms i have all checked for admin that is account i used
Thanks for help
15 Oct 2018 11:52 - 15 Oct 2018 12:02 #4 by Gautier
Could you post your logs after install of screen Customization plugin please.
Last edit: 15 Oct 2018 12:02 by Gautier.
21 Oct 2018 19:04 #5 by QUANTAMEDICAL
You will find attached log
Directory rights has been corrected on 10-09-2018
File Attachment:
File Name: projeqtor_...1012.log
File Size:5 KB
File Attachment:
File Name: projeqtor_...1015.log
File Size:12 KB
File Attachment:
File Name: projeqtor_...1009.log
File Size:11 KB
File Attachment:
File Name: projeqtor_...1011.log
File Size:6 KB
File Attachment:
File Name: projeqtor_...1010.log
File Size:7 KB
21 Oct 2018 19:50 #6 by babynus
There is an issue that may have led to bad configuration of plugin
This plugins (as others) will try move files under projeqtor structure
Here issue seems to stand on "../view/css/images/" that is readonly (for php user) so plugin installation cannot copy expected icons
Try and set access rights as 755 on all files and folders, at least during install of plugin.
Also take care that execution of plugin will require write access to folder projeqtor/model/custom
Try and fix and reinstall.
If menu does not appear, try and delete line with corresponding name in table plugin, and reinstall
This will force complete reinstall.
Time to create page: 0.059 seconds
