ProjeQtOr free project management software - paramAttachmentMaxSize - ProjeQtOr
18 Sep 2018 11:15 #1 by FARLSB
Projeqtor V7.0.8
As indicate in subject, i have a problem with paramAttachmentMaxSize.
I have changed the following parameters in php.ini as indicated in many post but nothing happen.
post_max_size=64M
upload_max_filesize=64M
I have also modified the maximum attachement file size in general parameters of Projeqtor (30097152 octes) but nothing happen.
I have restarted the service (WAMPSERVER).
I still with error "La taille du fichier excède la limite de 30097152 (paramAttchementmaxsize).
Do you have any idea to help me ?
Frédéric
18 Sep 2018 23:53 #2 by babynus
Replied by babynus on topic paramAttachmentMaxSize
What kind of file do you try and attach ?
What is size of file ?
19 Sep 2018 07:23 #3 by FARLSB
Replied by FARLSB on topic paramAttachmentMaxSize
This file is a print screen with PHP.INI configuration, error message and general configuration.
Jpeg file....195 ko.
19 Sep 2018 08:14 #4 by FARLSB
Sorry my previous reply was out of subject.
I try to attach an email (*.msg) directly from Outlook to Projeqtor by drag and drop.
I see the problem. It is impossible to attach the file directly from Outlook to Projeqtor, isnt'it ?
I have tried to attach the same file not directly from Outlook (I have put the email to harddisk before) and it works fine.
Frédéric
20 Sep 2018 18:11 #5 by babynus
Exactly.
You can find some Outlook plugins that will enable D&D from outlook to web page.
Otherwise solution is D&D to folder (or desktop), then D&D from there to web page.
