ProjeQtOr free project management software - [SOLVED] Error when trying to modify or delete a function cost on resource - ProjeQtOr
30 Aug 2018 18:51 #1 by louisc
As I didn't anticipated that I had configured charges in days and not in hours, when assigning function costs on resources I put the hourly cost instead of the daily cost.
I wanted to modify it and I can't as both modify and delete action don't work.
Looking at the debug console (on Microsoft Edge), I can see the following error when trying to modify or delete the resource function cost :
SCRIPT5007: Unable to set property 'value' of undefined or null reference (projectorDialog.js (4396, 2))
SCRIPT5007: SCRIPT5007: Unable to set property 'value' of undefined or null reference (projectorDialog.js (4397, 3))
I also tested on Chrome without success.
31 Aug 2018 19:41 #2 by babynus
I cannot reproduce on V7.1.5.
What is strange is that there is no line that can generate the issue on line 4396 of projectorDialog.js.
Which version are you using ?
03 Sep 2018 09:01 #3 by louisc
I'm still on v7.1.4, I can update to v7.1.5 and retry.
I also had a look at the .js file and did not see anything Strange but I'm really not an expert at Javascript.
03 Sep 2018 09:55 #4 by babynus
I checked version 7.1.4 : no line can generate issue on projeqtorDialog.js.
So possibly you have a cache issue.
Try and clean the cache of your browser (use the browser feature, not only F5 or Shift-F5)
19 Sep 2018 10:54 - 19 Sep 2018 10:56 #5 by louisc
Hi Pascal,
Sorry for late reply.
I updated to version 7.1.5, tried on a fresh Chrome (so no cache), and I get the same type of error :
I'm still unable to change or delete the daily rate for the ressources.
By the way, in the code now the lines correspond to the error :
Last edit: 19 Sep 2018 10:56 by louisc. Reason: Adding information
20 Sep 2018 18:34 #6 by babynus
OK, I get it.
I could reproduce.
Ticket #3584 recorded.
As it is an initialization issue, there is an easy workaround :
Before clicking on "trash" icon, click on "+" or on "edit".
Just cancel the pop-up displayed.
Then delete will work ;)
