ProjeQtOr free project management software - Margin: value not displayed if negative - ProjeQtOr
26 Jul 2018 14:43 #1 by phdesternes
We are not living in a perfect world, and sometimes the project margin could be negative :(
In such situation, the project's summary view indicates '0' as margin if it is between 0 and -9. From -10% and less (or more!), it's ok :huh:
Moreover, is it possible to convert the margin field from int(6) to decimal(2,2), as for projects with total amount of some millions, the decimal part becomes significant.
Thanks for support.
Philippe
26 Jul 2018 19:00 #2 by babynus
It's the real life :evil:
No, it works as expected (see below)
Is it really important as the workload (validated and reassessed) and costs are displayed with appropriate accuracy ?
26 Jul 2018 19:50 #3 by phdesternes
Thanks for your quick answer.
We are not talking about the same things. Your screenshot shows the Workload margin on the Today view.
I'm talking about the Cost margin on the Projects view (refer to attached)
Hope I was clear, if not feel free to ask.
Philippe
27 Jul 2018 11:58 #4 by babynus
OK, but margin is correctly displayed on project :
