ProjeQtOr free project management software - "Mails on event per project" not visible in top menu - ProjeQtOr
12 Jun 2018 10:17 #1 by caccia
Very small issue but it got me lost for a while :)
IN the top menu, when selecting "Controls & Automation" menu, the button for "Mails on event per project" is not visible.
The menu is accessible using the left side menu however.
12 Jun 2018 10:34 #2 by alainforma
You can enlarge icons using an option in user paramaters as shown into the attachement
12 Jun 2018 10:37 #3 by caccia
It's not actually the size which is an issue - it's that the "Mails on event per project" button doesn't appear in the top menu.
Access is granted, because the menu is available from the left side menu - I think it's just missing the link from "Mails on event per project" to "Controls & Automation" category in the top menu.
12 Jun 2018 11:03 #4 by alainforma
yes i ve got it ;-)
recorded as ticket # 3432
The following user(s) said Thank You: caccia
12 Jun 2018 16:17 #5 by babynus
Ticket #3432 fixed.
Will be included in patch V7.1.2
