ProjeQtOr free project management software - Sub Project Display - ProjeQtOr
Sub Project Display
17 May 2018 15:02 #1 by bioN
Sub Project Display was created by bioN
I've got an issue on sub Project display when i want to run planning calculation. Since i put the indentation mark's value to "none" on the user's parameters, i now have a little "no" mark before every sub projects.
with my example, i've got one proejct with 2 sub projects and each one are name "noSP1" and "noSP2" while i just want "SP1" and "SP2"
18 May 2018 11:13 #2 by babynus
Replied by babynus on topic Sub Project Display
Very strange, as :
1) I cannot reproduce...
2) Indentation mark is not used on the project selection list for planning calculation
Can you show print screen with indentation ="_" ?
Can you try and reproduce on demo.projeqtor.org ?
18 May 2018 11:42 #3 by bioN
Replied by bioN on topic Sub Project Display
Really strange, i tried to switch from "none" to "_" and again i get a little "no" instead of the "_" mark before every sub project.
Furthermore it seems that it don't happen every time :pinch:
here's the result the first time i tried what you've said
but when i thought it was the switch that may cause it , i tried it again and then nothing happen even the mark was still on the old value i had to relog and subProject were diplay correctly
21 May 2018 01:01 #4 by babynus
Finaly found issue : it aapears when you save a change on a project, then open plan dialog.
Will be fixed on next patch
(will also index this list according to selected sep char)
