ProjeQtOr free project management software - [SOLVED] Problem with cell expense (Validated) - ProjeQtOr
16 May 2018 11:13 #1 by jcroize
I have intalled the new version Projeqtor V6.5.7 to V7.0.8 and now i have a big problem with all projects the cells expenses.
This cell is locked and return to value 0 , impossible to redefined the good value.
And in the Activity after changes (exemple : imputation) the value Work and cost (Validated) return to value 0
Could you help me ?
16 May 2018 11:21 #2 by babynus
1) Post print screen to explain your case
2) Check value for global parameter parameter "consolidate validated work & cost" (should not be set to "always")
16 May 2018 11:29 #3 by jcroize
Thanks you for your reponse.
After change this parameter, now all is Ok after testing.
Thank you very much.
