ProjeQtOr free project management software - Problem when linking a milestone to a project - ProjeQtOr
16 May 2018 10:53 #1 by Bena
I want a project to start after a milestone from an other project.
When I try to link them, i have the following error in the log file :
2018-05-16 10:47:23.915 ***** ERROR ***** [V7.0.8] Impossible to load class Replan<br/>  => Not found in ../model/custom/Replan.php <br/>  => Not found in ../model/Replan.php <br/>  => Not found in ../model/persistence/Replan.php <br/>
2018-05-16 10:47:23.915 ----- DEBUG -----  => /projeqtor/projeqtor/tool/projeqtor.php at line 1371 called from debugPrintTraceStack
2018-05-16 10:47:23.915 ----- DEBUG -----  => called from projeqtorAutoload
2018-05-16 10:47:23.916 ----- DEBUG -----  => /projeqtor/projeqtor/model/PlanningElement.php at line 268 called from spl_autoload_call
2018-05-16 10:47:23.916 ----- DEBUG -----  => /projeqtor/projeqtor/tool/saveDependencyDnd.php at line 106 called from save for class PlanningElement
2018-05-16 10:47:23.916 ***** ERROR ***** [V7.0.8] EXCEPTION *****
2018-05-16 10:47:23.916 ***** ERROR ***** [V7.0.8] on file '/projeqtor/projeqtor/model/PlanningElement.php' at line (268)
2018-05-16 10:47:23.916 ***** ERROR ***** [V7.0.8] cause = Class 'Replan' not found
2018-05-16 10:47:23.916 ***** ERROR ***** [V7.0.8]    => #0 /projeqtor/projeqtor/tool/saveDependencyDnd.php (106) -> save()
Regards.
Bena
16 May 2018 11:16 #2 by babynus
2 workarounds :
1) Replan before creating dependency
2) Create dependency from tables successor / predecessor and not with Drag and Drop
Fix is to add 2 lines in /tool/saveDependencyDnd.php, before line 62, lie this :
if ($ref1Type=='Replan') $ref1Type='Project';
if ($ref2Type=='Replan') $ref2Type='Project';
$critPredecessor=array("refType"=>$ref1Type,"refId"=>$ref1Id);
$critSuccessor=array("refType"=>$ref2Type,"refId"=>$ref2Id);
Fix will be included in V7.1.0 and in patch for 7.0, if any.
The following user(s) said Thank You: Bena
