- Thank you received: 1
I tested, planning is recalculated after each updateIn an experiment, I selected task-5 and deleted the resource, which was assigned at 100% rate.
I again added the same developer, and assigned 40 hours of work at 20% rate.
This has no impact (it should say "no change to update")Then I saved the task.
If you are on screen ActivityWhich are the other use cases when we are NOT on this page, and therefore the recalculation does not automatically happen?
