ProjeQtOr free project management software - [SOLVED] Supervisor can not see copied project - ProjeQtOr
13 Apr 2018 08:14 #1 by AtomicStruct
When the supervisor copies a template, (including himself as resource) he cannot find the copy he made.
Settings: Organisation: 1 unit and 3 departments. The supervisor is head of a department. In "Access to data (project dependant)" He has Manager access.
If I switch it to Manager+, the problem is fixed, but then he sees way too much projects.
What am I doing wrong?
[using Projeqtor V7.0.3 on Apache 2.2 and PHP 5.6 on Synology RS3617xs]
13 Apr 2018 09:36 - 13 Apr 2018 09:44 #2 by babynus
Please describe you rights configuration (what you changes from default) because for me a Supervisor cannot create a project (so cannot copy existing one).
NB : you can test default behavior on Demo
[EDIT] I just tested changing rights of supervisor to Manager on Project : then supervisor can copy a project, and sees it correctly.
Last edit: 13 Apr 2018 09:44 by babynus.
The following user(s) said Thank You: AtomicStruct
13 Apr 2018 12:05 #3 by AtomicStruct
babynus wrote: Please describe you rights configuration (what you changes from default) because for me a Supervisor cannot create a project (so cannot copy existing one).
The settings are in the attachments. I did play around with these settings a lot.
babynus wrote: NB : you can test default behavior on Demo
OK, I will take a look there.
Thank you for the constructive answer.
13 Apr 2018 13:42 #4 by babynus
I checked your screenshots : all seems correct and will fit what I tested.
You changed supervisor access mode to Manager for project.
So supervisor can create new project, possibly copying another one.
When this is done, supervisor is automatically allocated to the project (to get rights to see it). Take care not to remove this allocation ;)
18 Jun 2018 12:15 #5 by AtomicStruct
Problem is solved after updating to Version 7.1.2
Thank you.
