ProjeQtOr free project management software - Issue on installation - ProjeQtOr
16 Nov 2011 23:31 #1 by babynus
*** Moving here a post that was on another topic but not dealing with same subject ****
Hi !
I have installed the news version 1.8.2, and when I want to logg me with the admin count, it 's not possible :
The right frame don't show anything. The left menu is ok. But the top and bottom menu is'not show
But it 's possible to connect me with an another count, all that ok !
Why ?
Thanks for your answer.
Jd rocard
16 Nov 2011 23:35 #2 by babynus
Replied by babynus on topic RE : Issue on installation
Can you check :
- Javascript console
- log file (by default on /file/logs)
and report any error.
29 Nov 2011 15:56 #3 by jdrocard
Replied by jdrocard on topic RE : Issue on installation
HELLO !
Escuse me for the long time to answer to you.
This is my log file :
2011-11-28 09:30:31 ===== TRACE ===== Login error for user 'rta'
2011-11-28 09:30:40 ===== TRACE ===== Login error for user 'rta'
2011-11-28 09:30:48 ===== TRACE ===== NEW CONNECTED USER 'rta'
2011-11-28 09:43:31 ===== TRACE ===== DISCONNECTED USER 'RTA'
2011-11-28 09:47:25 ===== TRACE ===== NEW CONNECTED USER 'dmo'
2011-11-28 09:54:12 ===== TRACE ===== DISCONNECTED USER 'DMO'
2011-11-28 09:54:24 ===== TRACE ===== NEW CONNECTED USER 'admin'
2011-11-28 09:54:24 ===== TRACE ===== Cannot check Version at projectorria.toolware.fr/getVersion.php
2011-11-28 09:54:24 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2011-11-28 09:54:54 ===== TRACE ===== DISCONNECTED USER 'admin'
2011-11-28 09:54:54 ***** ERROR ***** ERROR *****
2011-11-28 09:54:54 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\saveDataToSession.php' at line (11)
2011-11-28 09:54:54 ***** ERROR ***** cause = session_destroy() [<a href='function.session-destroy'>function.session-destroy</a>]: Session object destruction failed
2011-11-28 09:54:54 ===== TRACE ===== Cannot check Version at projectorria.toolware.fr/getVersion.php
2011-11-28 09:54:54 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2011-11-28 09:56:49 ===== TRACE ===== DISCONNECTED USER 'admin'
2011-11-28 09:56:56 ===== TRACE ===== NEW CONNECTED USER 'dmo'
2011-11-28 10:01:56 ***** ERROR ***** ERROR *****
2011-11-28 10:01:56 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:01:56 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:01:56 ***** ERROR ***** Error sending mail
2011-11-28 10:01:56 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:01:56 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:01:56 ***** ERROR ***** Sendmail path :
2011-11-28 10:01:56 ***** ERROR ***** Mail stored in Database : #220
2011-11-28 10:06:15 ***** ERROR ***** ERROR *****
2011-11-28 10:06:15 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:06:15 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:06:15 ***** ERROR ***** Error sending mail
2011-11-28 10:06:15 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:06:15 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:06:15 ***** ERROR ***** Sendmail path :
2011-11-28 10:06:15 ***** ERROR ***** Mail stored in Database : #221
2011-11-28 10:13:29 ***** ERROR ***** ERROR *****
2011-11-28 10:13:29 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:13:29 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:13:29 ***** ERROR ***** Error sending mail
2011-11-28 10:13:29 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:13:29 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:13:29 ***** ERROR ***** Sendmail path :
2011-11-28 10:13:29 ***** ERROR ***** Mail stored in Database : #222
2011-11-28 10:16:05 ***** ERROR ***** ERROR *****
2011-11-28 10:16:05 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:16:05 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:16:05 ***** ERROR ***** Error sending mail
2011-11-28 10:16:05 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:16:05 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:16:05 ***** ERROR ***** Sendmail path :
2011-11-28 10:16:05 ***** ERROR ***** Mail stored in Database : #223
2011-11-28 10:18:04 ===== TRACE ===== NEW CONNECTED USER 'rta'
2011-11-28 10:20:53 ***** ERROR ***** ERROR *****
2011-11-28 10:20:54 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:20:54 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:20:54 ***** ERROR ***** Error sending mail
2011-11-28 10:20:54 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:20:54 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:20:54 ***** ERROR ***** Sendmail path :
2011-11-28 10:20:54 ***** ERROR ***** Mail stored in Database : #224
2011-11-28 10:26:05 ***** ERROR ***** ERROR *****
2011-11-28 10:26:05 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:26:05 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:26:05 ***** ERROR ***** Error sending mail
2011-11-28 10:26:05 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:26:05 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:26:05 ***** ERROR ***** Sendmail path :
2011-11-28 10:26:05 ***** ERROR ***** Mail stored in Database : #225
2011-11-28 10:29:32 ===== TRACE ===== DISCONNECTED USER 'RTA'
2011-11-28 10:31:19 ***** ERROR ***** ERROR *****
2011-11-28 10:31:19 ***** ERROR ***** on file 'C:\Program Files\EasyPHP-5.3.6.0\www\projectorria\tool\projector.php' at line (581)
2011-11-28 10:31:19 ***** ERROR ***** cause = mail() [<a href='function.mail'>function.mail</a>]: Failed to connect to mailserver at &quot;localhost&quot; port 25, verify your &quot;SMTP&quot; and &quot;smtp_port&quot; setting in php.ini or use ini_set()
2011-11-28 10:31:19 ***** ERROR ***** Error sending mail
2011-11-28 10:31:19 ***** ERROR ***** SMTP Server : localhost
2011-11-28 10:31:19 ***** ERROR ***** SMTP Port : 25
2011-11-28 10:31:19 ***** ERROR ***** Sendmail path :
2011-11-28 10:31:19 ***** ERROR ***** Mail stored in Database : #226
But I dont find the javascript console, where is it ?
Best regard.
29 Nov 2011 15:57 #4 by jdrocard
HELLO !
Best regard.
29 Nov 2011 17:13 #5 by babynus
Nothing blocking appears on the log file (just misconfiguration of mail, so that mails are not sent).
For Javascript Console :
On FireFox : install Firebug
On Chrome : [Shift]+[Ctrl]+J
On IE : just forget ;)
