ProjeQtOr free project management software - [SOLVED] screenCustomization : errors during installation - ProjeQtOr
21 Mar 2018 12:18 #1 by sogeti
We have installed the screenCustomization plugin but have faced some errors during the installation. We are using ProjeQtor V6.4.4.
Here you can see the screenshot of the installation.
Do you know what these errors mean ?
Thank you in advance
21 Mar 2018 12:59 #2 by babynus
Which DB are you using ?
MySql or PortgreSql ?
21 Mar 2018 13:04 - 21 Mar 2018 13:05 #3 by babynus
Here is a fix as a workaround :
In model/history.php add 1 line after line 79, this way :
  public static function store ($obj, $refType, $refId, $operation, $colName=null, $oldValue=null, $newValue=null) {
    if ($operation!='insert' and SqlElement::isCopyInProgress()) return true; // On copy, only save history for inserts, not for all following updates during same operation
    if (!$refType or !$refId) return true; // Workaround
Last edit: 21 Mar 2018 13:05 by babynus.
21 Mar 2018 13:31 #4 by sogeti
We are using PostgreSql
21 Mar 2018 13:47 - 21 Mar 2018 13:48 #5 by babynus
OK
Did you try the patch as proposed below ?
Last edit: 21 Mar 2018 13:48 by babynus.
21 Mar 2018 14:12 #6 by sogeti
Thank you for your replies.
We are not able to try it right now but do you think there will be a bad impact to go on using the plugin knowing that we had these errors ?
