ProjeQtOr free project management software - Getting Issue in Installation of projeqtor 7.0.0 - ProjeQtOr
21 Mar 2018 07:40 #1 by Ganesh
I am Trying to install but getting error in installation
Parse error: syntax error, unexpected [ in /home/soft/public_html/manual/projeqtor700/tool/projeqtor.php on line 444
system configuration
  • PHP 5.3.33
  • mysql 5.5
  • Apache 2.2
projeqtor 7.0.0 is looking for minimum 5.2 php version
21 Mar 2018 09:11 #2 by babynus
We did not mention it, sorry (I'll add it on the changelog and technical requirements), but ProjeQtOr V7.0 requires ate least PHP 5.4.
We've fixed the part you point out so you'll be able to install V7.0.1 on PHP 5.3, but some external libraries have been upgraded to assume compatibility with PHP 7.2.
Some on PHP 5.3, some features won't work, such as :
- email sending
- export to pdf
- possibily other features using external libraries
We highly recommand to use at least PHP 5.6, and if you have the opportunity to miograte to PHP 7.0 ou 7.1, please do : you'll get much better performance.
