ProjeQtOr free project management software - [SOLVED] Rights screenCustomization_V5.0 - ProjeQtOr
26 Dec 2017 10:54 #1 by cbnt
I tried to install plugin screenCustomization v5.0 ont Projeqtor v6.5.1. I got an error like this :
2017-12-26 13:37:07.999 ===== TRACE ===== New plugin found : screenCustomization_V5.0.zip
2017-12-26 13:37:08.008 ===== TRACE ===== Plugin unzipped succefully
2017-12-26 13:37:08.009 ***** ERROR ***** [V6.5.1] ERROR *****
2017-12-26 13:37:08.009 ***** ERROR ***** [V6.5.1] on file '/appli/projects/projeqtor/apache_2.4/htdocs/projeqtor/projeqtor/model/Plugin.php' at line (171)
2017-12-26 13:37:08.009 ***** ERROR ***** [V6.5.1] cause = copy(../view/css/images/iconScreenCustomization16.png): failed to open stream: Permission denied
For information, the file is uploaded trought the web interface, in the plugin section.
You have to know that on my server, MySQL is installed with a user named "w3user" (files/folders installation for the database) and Apache with a user named "webadm". These 2 users are in the same group named "webgrp".
When file is uploaded, i see :
-rw-rw-r-- 1 w3user webgrp 468172 Dec 26 13:47 screenCustomization_V5.0.zip
When i launch the installation with the web interface, i see these rights ans I get the error above.
drwxrwxr-x 5 w3user webgrp 4096 Dec 26 13:48 screenCustomization
Rights in the destination folder are fine for me :
view/css/images drwxrwxr-x 2 webadm webgrp 36864 Dec 26 12:54 .
Is there a way to manuallay install my uloaded plugin with differents rights ?
I saw in the other parts of the forum that php files must "apache" owner. Does it the same with .sql files ? .js files ? .xml files ?
Thanks for your answers / suggestions
31 Dec 2017 12:56 #2 by babynus
This is an acces right issue.
But it is strange as reported issue is not relevant with your access rights.
Possibily issue is not on the target, but on the source.
Web user must have write access right on whole folder "plugin"
Try and manually unzip the plugin file and check access rights to unzipped folder (the one with the name of the plugin)
You should try and fiw access right to us install procedure.
Manual install will sure not be complete.
02 Jan 2018 09:44 #3 by cbnt
Thank you for your answer.
I agree there is something strange. We have modified the access rights to 777 on the folder ../view/css/images/*. Then the plugin installed sucessfully.
2017-12-27 12:57:27.036 ===== TRACE ===== New plugin found : screenCustomization_V5.0.zip
2017-12-27 12:57:27.048 ===== TRACE ===== Plugin unzipped succefully
2017-12-27 12:57:27.058 ===== TRACE ===== Plugin descriptor information :
2017-12-27 12:57:27.058 ===== TRACE ===== => name : screenCustomization
2017-12-27 12:57:27.058 ===== TRACE ===== => description : Customization of screens
2017-12-27 12:57:27.058 ===== TRACE ===== => version : 5.0
2017-12-27 12:57:27.058 ===== TRACE ===== => compatibility : V6.4.2
2017-12-27 12:57:27.058 ===== TRACE ===== =====================================
2017-12-27 12:57:27.059 ===== TRACE ===== PLUGIN SQL FILE : ../plugin/screenCustomization/screenCustomization.sql
2017-12-27 12:57:27.061 ===== TRACE ===== 1 lines inserted into table "menu".
2017-12-27 12:57:27.063 ===== TRACE ===== 1 lines inserted into table "habilitation".
2017-12-27 12:57:27.071 ===== TRACE ===== Table "plgcustomlist" created.
2017-12-27 12:57:27.080 ===== TRACE ===== Index "plgcustomlistScope" created.
2017-12-27 12:57:27.080 ===== TRACE ===== DATABASE UPDATED
2017-12-27 12:57:27.080 ===== TRACE ===== WITH NO ERROR
2017-12-27 12:57:27.080 ===== TRACE ===== Plugin updated database with 0 errors from script ../plugin/screenCustomization/screenCustomization.sql
2017-12-27 12:57:27.633 ===== TRACE ===== Plugin screenCustomization V5.0 completely deployed
Here the users/rights in the folder projeqtor :
view
drwxrwxrwx 7 webadm webgrp
css
drwxrwxrwx 4 webadm webgrp
images
drwxrwxrwx 2 webadm webgrp
It seems that "other" needs write access to the folder. Is there any other accounts that needs rights to install ? May be the problem is between accounts/groups/rights on the system.
Before solving this issue, i would try to set 775 rights on the folder and test the plugin in the interface.
Best regards,
03 Jan 2018 14:58 #4 by babynus
As long I as know, only user running PHP must have write access to the folders.
09 Jan 2018 09:47 #5 by cbnt
I've modified with 775 rights /view/css/images. Plugin seems to be ok.
Thank for your help.
