ProjeQtOr free project management software - Plugin screen Customization - Ticket - red block - ProjeQtOr
15 Dec 2017 10:39 #1 by alexjoet
When the field "task" of the form is set to "not visible" in the "Screen customization > Ticket", the ticket cannot be updated > a red block says we must look at the log file :
For exemple:
2017-12-15 10:18:21.396 ***** ERROR ***** [V6.4.3] Exception-[23000] SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'Ticket-2370' for key 'workelementReference'
2017-12-15 10:18:21.399 ***** ERROR ***** [V6.4.3] For query : insert into workelement ( refType , refId , idActivity , idProject , refName , realCost , idUser , ongoing , done , idle ) values ('Ticket', '2370', '2450', '352', '[tests] Page “Ajouter une séance”', '4409738.09', '144', '0', '0', '0')
2017-12-15 10:18:21.403 ***** ERROR ***** [V6.4.3] Strack trace :
2017-12-15 10:18:21.406 ***** ERROR ***** [V6.4.3] #0 Sql->query called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:1120]
2017-12-15 10:18:21.410 ***** ERROR ***** [V6.4.3] #1 SqlElement->insertSqlElement called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:929]
2017-12-15 10:18:21.413 ***** ERROR ***** [V6.4.3] #2 SqlElement->saveSqlElement called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:619]
2017-12-15 10:18:21.416 ***** ERROR ***** [V6.4.3] #3 SqlElement->save called at [C:\wamp\www\projeqtor\model\WorkElementMain.php:177]
2017-12-15 10:18:21.420 ***** ERROR ***** [V6.4.3] #4 WorkElementMain->save called at [C:\wamp\www\projeqtor\model\WorkElementMain.php:322]
2017-12-15 10:18:21.424 ***** ERROR ***** [V6.4.3] #5 WorkElementMain->save called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:1529]
2017-12-15 10:18:21.427 ***** ERROR ***** [V6.4.3] #6 SqlElement->saveDependantObjects called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:1467]
2017-12-15 10:18:21.430 ***** ERROR ***** [V6.4.3] #7 SqlElement->updateSqlElement called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:923]
2017-12-15 10:18:21.434 ***** ERROR ***** [V6.4.3] #8 SqlElement->saveSqlElement called at [C:\wamp\www\projeqtor\model\persistence\SqlElement.php:619]
2017-12-15 10:18:21.437 ***** ERROR ***** [V6.4.3] #9 SqlElement->save called at [C:\wamp\www\projeqtor\model\TicketMain.php:390]
2017-12-15 10:18:21.441 ***** ERROR ***** [V6.4.3] #10 TicketMain->save called at [C:\wamp\www\projeqtor\tool\saveObject.php:78]
16 Dec 2017 16:25 #2 by babynus
This is an issue happening when setting as "readonly" or "hidden" the object "workelement" on Ticket.
This is fixed on V6.5.1 (coming soon)
