ProjeQtOr free project management software - closed Ticket - ProjeQtOr
closed Ticket
11 Dec 2017 12:29 #1 by Durou C
closed Ticket was created by Durou C
I can't close ticket and modify the result...
I have got this error message:
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'idAccountable' in 'field list'
in log file:
2017-12-11 12:22:57.832 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.837 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.889 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.892 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.893 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.894 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.897 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.900 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.927 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:57.933 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.760 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.764 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.814 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.821 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.822 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.825 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.828 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.831 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.832 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'idAccountable' in 'field list'
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] For query : update ticket set idStatus='19' , idAccountable='30' , idle='1' , idleDateTime='2017-12-11 12:20:00' , lastUpdateDateTime='2017-12-11 12:22:59' where id=149
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] Strack trace :
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:1412]
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] #1 SqlElement->updateSqlElement called at [/var/www/projeqtor/model/persistence/SqlElement.php:923]
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] #2 SqlElement->saveSqlElement called at [/var/www/projeqtor/model/persistence/SqlElement.php:619]
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] #3 SqlElement->save called at [/var/www/projeqtor/model/TicketMain.php:401]
2017-12-11 12:22:59.837 ***** ERROR ***** [V6.5.0] #4 TicketMain->save called at [/var/www/projeqtor/tool/saveObject.php:78]
2017-12-11 12:23:00.003 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.417 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.420 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.471 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.473 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.474 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.475 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.477 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.479 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
2017-12-11 12:25:07.500 ***** ERROR ***** [V6.5.0] Error on SqlElement to get 'idAccountable' for Class 'Ticket' : field 'idAccountable' not found in Database.
11 Dec 2017 16:02 #2 by Durou C
Replied by Durou C on topic closed Ticket
I downgrade to 6.4.4, all it works...
11 Dec 2017 16:56 #3 by babynus
Replied by babynus on topic closed Ticket
It looks like you run code of V6.5 with db structure of V6.4
11 Dec 2017 17:00 #4 by Durou C
but when I upgrade to 6.5, the db structure don't update in the same time ?
12 Dec 2017 10:16 #5 by babynus
Remind of migration process:
- overwrite existing code with new one (do not install on new folder)
- reconnect as admin to finalize migration
If it is what you did, please post log file corresponding to upgrade process.
12 Dec 2017 10:19 #6 by Durou C
I did this it's ok now...
but I have another problem.
In Kanban, when I drop activité finished to closed I have this message:
TypeError: null is not an object (evaluating 'dojo.byId('divPrincItem'+id).innerHTML=splitData[1].split('[splitcustom2]')[0]')
Contactez votre administrateur
(l'erreur détaillée est consignée dans le fichier de log)
and nothing in log file.
