ProjeQtOr free project management software - Removing resource from project - ProjeQtOr
11 Oct 2017 06:53 #1 by kobetsu
Hi
Is it expected behaviour than when I have project with defined resources, I add my self there with administrator rights (I'm administrator at all as well I have profile of administrator inside project) I cannot remove other resources of the project. To remove resources of the project I need first edit given resource, change its profile inside project to exactly equal to mine (so administrator) and then I can remove it.
So seems I can remove only resources of the same profile as mine... sounds not bad in general however is it not expected that highest profiles like administrator can do more ?
13 Oct 2017 20:19 #2 by babynus
Check access rights and access mode.
Maybe oyu defined that admin cannot remove affectation, but can change it...
Also check order for Profiles : you cannot change allocation to projects for profiles "higher" than yours.
Smaller sort order gives hight profile.
So if you moved admin or created new profiles with order zero, this is normal.
