ProjeQtOr free project management software - Issue when accessing to planning view - ProjeQtOr
20 Sep 2017 13:54 #1 by madrilene59
i have a problem since i've done the update tu 6.4
When i'm logging with admin account, i can see the planning view.
but if i'm logging with my user account, i can't see it.
I was able to see it when a used older version.
I have an error in the log saying
2017-09-20 13:45:38.949 ***** ERROR ***** [V6.4.0] Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'proplanningelement.idProduct' in 'IN/ALL/ANY subquery'
2017-09-20 13:45:38.950 ***** ERROR ***** [V6.4.0] For query : select proplanningelement.* from proplanningelement where proplanningelement.idle=0 and ((proplanningelement.idProject in (4, 6, 9, 11, 12) or (proplanningelement.idProject is null and proplanningelement.idProduct in (select idProduct from proversion existV, proversionproject existVP where existV.id=existVP.idVersion and existVP.idProject in (4, 6, 9, 11, 12)))) or ((1=4) and proplanningelement.idProject in (0) ) or ((1=3) and proplanningelement.idProject in (0) )) and (proplanningelement.idProject not in (0) or proplanningelement.idProject is null ) and proplanningelement.idProject in (6, 4, 9, 11, 12) and proplanningelement.idProject not in (0, 5, 7) order by proplanningelement.wbsSortable
2017-09-20 13:45:38.950 ***** ERROR ***** [V6.4.0] Strack trace :
2017-09-20 13:45:38.951 ***** ERROR ***** [V6.4.0] #0 Sql->query called at [/home/guiguifrrs/www/projeqtor/tool/jsonPlanning.php:230]
2017-09-20 13:45:38.951 ***** ERROR ***** [V6.4.0] #1 include called at [/home/guiguifrrs/www/projeqtor/view/planningList.php:409]
2017-09-20 13:45:38.951 ***** ERROR ***** [V6.4.0] #2 include called at [/home/guiguifrrs/www/projeqtor/view/planningMain.php:48]
thanks for helping
20 Sep 2017 18:21 #2 by babynus
Issue recorded as Ticket #2972
NB as a workaround waiting for fix you can uncomment line 940 and uncomment line 941 in projeqtor.php
The following user(s) said Thank You: madrilene59
20 Sep 2017 18:50 #3 by madrilene59
Thanks it's working
