ProjeQtOr free project management software - Unable to create projects - ProjeQtOr
18 Sep 2017 04:57 #1 by keyaoting
I am trying to test out by creating a project. However, it states that there is an ERROR occurred (10.50:38)
The log file indicated that "A non-numeric value encountered".
I tried using V6.3.5 and V6.3.6, both exhibit the same problem.
Anyway to solve it?
18 Sep 2017 08:04 #2 by babynus
Replied by babynus on topic Unable to create projects
You are using php 7.1
ProjeQtOr V6.3 is not compatible with PHP V7.1
The following user(s) said Thank You: keyaoting
19 Sep 2017 09:07 #3 by keyaoting
Replied by keyaoting on topic Unable to create projects
Thank you. It works.
However, other bugs were found after I downgrade my PHP to 5.6.
