ProjeQtOr free project management software - Workflow display - ProjeQtOr
Workflow display
04 Nov 2011 21:14 #1 by ThierrC49
Workflow display was created by ThierrC49
Hello Babynus
When I would like to edit a work flow I see the flowchart but not the matrix to change it. the spindle (ascenceur) is not present or inactive. if I mask the upper area I can only see the starter of matrix that all.
I'm using 1.8.2 and try it on FF, EI and Chrome with same issue
Thank
Thierry,
05 Nov 2011 00:54 #2 by babynus
Replied by babynus on topic RE : Workflow display
I cannot reproduce.
Could you send a print screen to This email address is being protected from spambots. You need JavaScript enabled to view it. ?
16 Nov 2011 17:41 - 16 Nov 2011 17:48 #3 by fredparis
Replied by fredparis on topic RE : Workflow display
Hi Babynus,
I see the same problem : the screen area where is the flowchart of a workflow, (when editing a workflow, as administrator), is without scroll bars.
As the flowchart don't fit in the window, we can't scroll up or down, left or right to see the rest of the chart.
Another minor detail, in french language, the title of the flowchart is "Giagram de workflow" instead of "Diagramme de workflow".
Thanks for your help,
16 Nov 2011 23:25 #4 by babynus
hI,
Thierry solved his problem be reinstalling last version.
Maybe you can try this.
But for now I cannot explain what's happening...
Let me know if reinstalling solves this issue for you.
Regards.
25 Nov 2011 22:05 #5 by ThierrC49
Replied by ThierrC49 on topic RE : Workflow display
Hello Fred,
To solve this I had used a new database. I don't find exatly why original database was corrupted but I have done some test on this and it could be the reason.
And you do you perform any test on you database that can explain the issue?
BR
Thierry,
07 Dec 2011 00:56 #6 by tsorenson
Replied by tsorenson on topic RE : Workflow display
Is there any more information on this issue as I am experiencing the same thing. I have tried re-installing everything and still everything past the workflow diagram is not accessible. No scroll bars show up.
