ProjeQtOr free project management software - Real Work allocation Error - ProjeQtOr
07 Jul 2017 09:46 #1 by Marina
Dear experts,
When we are trying to allocate units to a project using the 'Follow-up --> Real Work Allocation' module the attached error appears and we are not able to save the time allocated.
This happens to all aur projects so we can not save the time spent to each one of them. Any suggestions on how to resolve this issue?
Thank in advance for yopur help.
Kind Regards,
Marina
09 Jul 2017 20:15 #2 by babynus
Replied by babynus on topic Real Work allocation Error
Error is clean : you must increase the max_input_vars in your php.ini
10 Jul 2017 09:27 #3 by Marina
Replied by Marina on topic Real Work allocation Error
Thank you for your reply.
However it is not clear to us how we can increase the max_input_vars in the php.ini.
Could ypu please guide us through this process?
Thank you in advance for your help.
Kind Regards,
Marina
10 Jul 2017 15:36 #4 by richard.pare
max_input_vars is a parameter in the php.ini file. You must edit this file to change value of parameter.
So file location depends on OS and http server used.
Look on Internet to find localization of file.
The new value of parameter will be take into account after http server restart.
10 Jul 2017 17:38 #5 by Marina
We follow these steps :
1. Founfd the file
2. Increase the max_input_vars to 5000.
3. Restart.
However the following error continues to appear:
'Unknown: Input variables exceeded 1000. To increase the limit change max_input_vars in php.ini. in Unknown on line 0
Contact your administrator.'
Any suggestions what might be wrong?
Kind Regards,
Marina
10 Jul 2017 23:59 #6 by richard.pare
Possibility to have two php.ini file.
One for PHP command line and another for http server.
It is also possible to overwrite parameter value in an other ".ini" file located in a subdirectory.
