ProjeQtOr free project management software - Copy a project - ProjeQtOr
Copy a project
05 Jul 2017 11:57 #1 by Damien Gozillon
I created Default Projet or Model (Modele in French).
The problem is I cannot copy it. I have an error message (see attachement).
I put a date and charge in every task (it should'nt be necessary in a model anyway...) but I still have this message.
I tried to cha,ge the type of projet but I still have the mesage.
And I can't see where is the problem.
Can you please help me ?
05 Jul 2017 14:36 #2 by Damien Gozillon
Replied by Damien Gozillon on topic Copy a project
There was some task with a validated duration of 0. Wich is normal if the task is "planification" for example. So I solved my problem but there is still an issue. At least the error message should say where is the problem (which task).
05 Jul 2017 15:06 #3 by richard.pare
Replied by richard.pare on topic Copy a project
This isn't an error.
You use the planning mode "Fixed duration" who forcing you to set the duration date.
If you want don't see the message anymore, change to a floating planning mode.
May be the "project template" feature can be improved for fixed planning modes.
The following user(s) said Thank You: Damien Gozillon
05 Jul 2017 15:22 #4 by Damien Gozillon
thanks for your answer.
I can set the planning mode on a task but I can see where you can set it on the project?
Because there was no error on tasks. Only on the project when I tried to copy it.
07 Jul 2017 16:39 #5 by babynus
Replied by babynus on topic Copy a project
There is no planning mode on project, only on activity.
The error is on the task. What is weird is that you should have the error on the template...
Can you try and update every activity of the template to identify source ?
08 Jul 2017 00:06 #6 by Damien Gozillon
I did another try and I have the same message. I refreshed everytask, replanified, and still no task in error. This time again I have a validated duration at zero, to planify as soon as possible, with a planified duration of 1 wheras the begin and end date are the same.
