ProjeQtOr free project management software - Display error in project detail - ProjeQtOr
05 Jul 2017 09:09 #1 by rochatde
I installed projeqtor 6.2.5 and created some projects.
When I want to modify a project I have an error in the screen (a red rectangle in place of datas). I search the logs in the webserver and in the projeqtor log and now I dont know how to solve this problem.
As anyone an idea ?
Dominique
07 Jul 2017 16:23 #2 by babynus
It is a zlib issue.
Try and upgrade your PHP or disable zlib output compression (zlib_output_compression=off in php.ini)
