ProjeQtOr free project management software - [SOLVED] Problem with planned end date - ProjeQtOr
22 Jun 2017 16:11 #1 by #Chris
I have planned a project which should have started last year in August. The validated start date was 22/08/2016 and the end date 30/09/2016. But now we could only start at 13/06/2017. So I set the project on ‘in progress’ on 13/06/2017 but didn’t change the validated dates. The program changed the planned date to the actual start date but didn’t change the planned end date. So I got an error note because the planned end date is before the start date. But now I can’t change anything. Is this a bug or is it my mistake? What can I do?
Enclosed I send you a screenshot of the problem. As you can see the gantt chart is right.
Thanks you very much for your help! :)
22 Jun 2017 19:06 #2 by babynus
Just run planning calculation to fix this.
23 Jun 2017 11:45 - 23 Jun 2017 11:48 #3 by #Chris
I did it already. So the bar in the gantt chart has 'slipped' to the correct date. But the written planned end date in the activity didn't change.
And I also cann't change the validated end date to the future now. (see file attached)
Last edit: 23 Jun 2017 11:48 by #Chris.
23 Jun 2017 14:03 #4 by babynus
Are you using latest V6.2.5 ?
(if not, consider migrating)
23 Jun 2017 17:37 #5 by #Chris
Yes, we use already V6.2.5
Do you need any more niformation?
27 Jun 2017 23:52 #6 by babynus
From what I can see on screenshot, you don't have assigned work.
Try and add at least 0,1 assigned work and replan (then you can remove added work if you please)
