ProjeQtOr free project management software - [SOLVED] Added Attachements inside a project do not appear in Documents of the project - ProjeQtOr
18 May 2017 12:31 #1 by naceur.ayachi@tsi.com.tn
Added Attachements inside a project do not appear in Documents of the project and vice-versa
In fact I consider that Documents and attachements are the same so if I add an attachement to a project I want to find it with the documents of the project
Also when I add a document I want to find it within attachements.
Why does it not work this way?
18 May 2017 17:03 #2 by babynus
It is normal :)
No, they are completely different B)
That's why we have designed two different ways to store files :evil:
Attachment are just... attached files (like you may find on emails)
They are attached to an object (ticket, activity, project or else) and cannot be seen elsewhere.
They are not versionned.
Document are files you want to manage in configuration (follow versions).
Then when you create a document, you just define the metadata foir the document.
You attach the files to the versions of the document.
If you want to see both as Documents and on Project, you should not use attachements.
Always use Documents and Document Versions and link Documents (or Document Versions) to the projects.
The following user(s) said Thank You: naceur.ayachi@tsi.com.tn
18 May 2017 17:42 #3 by naceur.ayachi@tsi.com.tn
OK.
Now every thing is clear about documents vs attachements
