ProjeQtOr free project management software - Misplaced organizeButtonsEnd() call - ProjeQtOr
16 May 2017 08:59 #1 by antonio.grr
Hi.
At first sight it seems that the call to the function organizeButtonsEnd() in objectButtns is inside the if ($mailable and $mailable->id) ;
but I believe it must be called in any case, as the organizeButtons() sequence is alredy started. Please check.
In my version I created function fro each button ( e.g. function drawMultiUpdateButton($objectClass, $objectClassi18n, $noselect) ) so the code appears more readable, like
//$displayButton=( $buttonCheckListVisible=="visible")?'void':'none';
if ($buttonCheckListVisible == "visible" and $obj->id) {
$this->organizeButtons($obj);
$this->drawCheckListButton($objectClass, $buttonCheckListVisible);
$paramHistoryVisible = Parameter::getUserParameter('displayHistory');
if ($paramHistoryVisible == 'REQ' and $obj->id) {
$this->drawHistoryButton($objectClass, $objectId, $paramHistoryVisible);
$this->organizeButtonsEnd();
Best regards
17 May 2017 09:00 #2 by babynus
You're right,
In fact, it is the closure for test "if ($mailable and $mailable->id" that is much to far.
In encloses several buttons that should be displayed even if not mailable (history, checklist, ...)
Thanks for reporting.
