ProjeQtOr free project management software - Big slowdown - Page 2 - ProjeQtOr
Big slowdown
14 May 2017 12:18 #7 by babynus
Replied by babynus on topic Big slowdown
You can choose in the global Parameters between :
- Library PHPMailer
- Function PHPMail
- Connexion throught Socket
15 May 2017 08:49 #8 by Durou C
Replied by Durou C on topic Big slowdown
What's the difference beetween the 3 choices ?
15 May 2017 18:20 #9 by babynus
- Library PHPMailer
=> uses de widely spread PHPMailer library, able to connect to smtp server with or without authentication, over ssl or not
=> it is the advised selection
- Function PHP Mail
=> uses the mail function included in PHP. It is a low level function that has limitation (cannot connect with authentication without ssl)
=> implements a direct connection to the smtp server using Socket. It is a very low level way to do, that will not be allowed by all smtp servers.
06 Jun 2017 09:56 #10 by Durou C
I have always my trouble with mail fonction, I try to use the 3 different method, but nothing work... I cannot send mail with projeqtor !
