ProjeQtOr free project management software - 6.2.2 Little fix for saving - ProjeQtOr
24 Apr 2017 11:22 - 24 Apr 2017 11:22 #1 by papjul
One of 6.2.2 fixes was not well done: sourceforge.net/p/projectorria/code/3962/#diff-10
Could you please change:
} else if (dojo.byId('objectClass') && dojo.byId('objectId')) {
    var url = '../tool/getObjectCreationInfo.php?objectClass='+ dojo.byId('objectClass').value +'&objectId='+dojo.byId('objectId').value;
    loadDiv(url, 'buttonDivCreationInfo', null);
    if (validationType != 'note' && validationType != 'attachment') {
      formInitialize();
    hideWait();
into
} else {
      formInitialize();
    hideWait();
in projeqtor.js at line ~1420
Have a look at code of version 6.1.x if you don’t understand why this should be done like this.
Thanks,
Last edit: 24 Apr 2017 11:22 by papjul.
24 Apr 2017 14:38 #2 by babynus
Replied by babynus on topic 6.2.2 Little fix for saving
You're right.
Thanks for the fix.
27 Apr 2017 15:11 #3 by pipobru
Replied by pipobru on topic 6.2.2 Little fix for saving
on my instal this modification not run. Without error but no login are possible.
27 Apr 2017 15:18 #4 by papjul
Replied by papjul on topic 6.2.2 Little fix for saving
Make sure you didn’t forget a bracket and share with us your JavaScript console logs.
27 Apr 2017 15:41 - 27 Apr 2017 15:51 #5 by pipobru
very strange I re test for record js console log and the login is OK .... Sorry And after a check i have omit a { caracter after the first ELSE. Sorry again :-)
Last edit: 27 Apr 2017 15:51 by pipobru.
