ProjeQtOr free project management software - KPI : SQL error - ProjeQtOr
KPI : SQL error
13 Apr 2017 14:27 #1 by louisc
KPI : SQL error was created by louisc
Looking at the logs while I can't manage to get consolidated KPI, I found a lot of Exceptions concerning essentially h.year and h.month column not found in the database.
2017-04-12 17:38:11.508 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'h.y
ear' in 'where clause'
2017-04-12 17:38:11.508 ***** ERROR ***** For query : select * from deliverable where idProject=420 and h.year='2016' and deliverable.scope = 'Deliverable' order by plannedDate asc
2017-04-12 17:38:11.508 ***** ERROR ***** Strack trace :
2017-04-12 17:38:11.508 ***** ERROR ***** #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1840]
2017-04-12 17:38:11.508 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/report/kpiDeliverable.php:246]
I wonder if the problems comes from a bad database update when migrating to 6.1.3 or if the problem comes from elsewhere.
Thanks for your help.
14 Apr 2017 20:38 #2 by babynus
Replied by babynus on topic KPI : SQL error
Could you please post the whole error stack ?
06 Jul 2017 23:07 #3 by louisc
Replied by louisc on topic KPI : SQL error
This was due to Organization not configured correctly.
When everything is well configured there are no more problems.
