ProjeQtOr free project management software - [SOLVED] Error at first loggin - ProjeQtOr
06 Feb 2017 15:39 #1 by boooon
Error at first loggin was created by boooon
hi,
I installed and made the first configuration of projeQtor V6.0.8.
An error occured when I try to log on :
I saw some error into the logs file
File Attachment:
File Name: projeqtor_...0206.log
File Size:200 KB
Could you help me to understand please ?
07 Feb 2017 21:42 #2 by babynus
Replied by babynus on topic Error at first loggin
Log files shows trange errors.
Firts integrity constraints on insert request that have no reason to already have existing keys...
Then, at end, report for upgrade to 1.6.1 already having upgraded to 6.0.6....
At least, issue apperars on strlen($val) from string convertion, while upgrading bills, but database should be empty...
1) is your database empty or not ?
2) Is it shared or dedicated to your own projeqtor need ?
3) what version of PHP ?
4) what version of MySql ?
Thanks for your answers.
08 Feb 2017 09:04 #3 by boooon
Replied by boooon on topic Error at first loggin
thx for your answer,
Before I post this topic, I tried to re-install projeQtor by deleting the parametersLocation.php file. So, it could explain some error like existing keys.
I didn't insert anything into the database.
It is shared with other self made applications.
5.2.1
5.0.27
08 Feb 2017 20:00 #4 by babynus
1) try and reinstall from scratch, removing code and existing data
2) if you habe the opportunity, try and upgrade your php version (even if ProjeQtOr should be compatible with php 5.2, it's a long time since I did not use such an old version)
10 Feb 2017 10:14 #5 by boooon
Php has been upgraded. It works now !
Thanks !
