ProjeQtOr free project management software - Error with print to pdf - ProjeQtOr
20 Dec 2016 14:34 #1 by pipobru
Hello i have this error when i use printtopdf function in planning:
2016-12-20 14:14:51.083 ***** ERROR ***** EXCEPTION *****
2016-12-20 14:14:51.083 ***** ERROR ***** on file '/var/www/html/external/html2pdf/vendor/tecnickcom/tcpdf/tcpdf.php' at line (2927)
2016-12-20 14:14:51.083 ***** ERROR ***** cause = TCPDF ERROR: Some data has already been output, can't send PDF file
2016-12-20 14:14:51.083 ***** ERROR ***** => #0 /var/www/html/external/html2pdf/vendor/tecnickcom/tcpdf/tcpdf.php (7620) -> Error()
2016-12-20 14:14:51.083 ***** ERROR ***** => #1 /var/www/html/external/html2pdf/html2pdf.class.php (390) -> Output()
2016-12-20 14:14:51.083 ***** ERROR ***** => #2 /var/www/html/view/print.php (239) -> Output()
2016-12-20 14:14:51.083 ***** ERROR ***** => #3 /var/www/html/view/print.php (183) -> finalizePrint()
I have solve with this modification:
In /var/www/html/view/print.php i have add this line: ob_end_clean(); after line 238 ($html2pdf->writeHTML($html2pdf->getHtmlFromPage($content));)
20 Dec 2016 14:44 #2 by babynus
Replied by babynus on topic Error with print to pdf
Thnaks for the workaround.
It will be included in next version / patch
But source is due to incorrecly ended class file.
Could you tell us what did you want to export as PDF when you got the issue ?
20 Dec 2016 14:49 #3 by pipobru
Replied by pipobru on topic Error with print to pdf
I would to export my gantt planning. Print gantt planning is very important for display in office or communicate by PDF with customer.
