ProjeQtOr free project management software - customization screen tickets works - ProjeQtOr
19 Dec 2016 11:15 #1 by Durou C
when I want to change estimated work to required... there is an error:
2016-12-19 11:11:03.949 ***** ERROR ***** ERROR *****
2016-12-19 11:11:03.949 ***** ERROR ***** on file '/var/www/projeqtor/tool/generateImputationAlert.php' at line (113)
2016-12-19 11:11:03.950 ***** ERROR ***** cause = Undefined index: workDetail
2016-12-19 11:11:41.643 ***** ERROR ***** securityGetAccessRightYesNo : '' is not an existing object class
2016-12-19 11:11:41.643 ***** ERROR ***** securityGetAccessRightYesNo(menu, update, Ticket #, )
2016-12-19 11:11:41.643 ***** ERROR ***** ERROR *****
2016-12-19 11:11:41.643 ***** ERROR ***** on file '/var/www/projeqtor/tool/projeqtor.php' at line (1606)
2016-12-19 11:11:41.643 ***** ERROR ***** cause = First parameter must either be an object or the name of an existing class
2016-12-19 11:11:47.948 ***** ERROR ***** securityGetAccessRightYesNo : '' is not an existing object class
2016-12-19 11:11:47.948 ***** ERROR ***** securityGetAccessRightYesNo(menu, update, Ticket #, )
2016-12-19 11:11:47.948 ***** ERROR ***** ERROR *****
2016-12-19 11:11:47.948 ***** ERROR ***** on file '/var/www/projeqtor/tool/projeqtor.php' at line (1606)
2016-12-19 11:11:47.948 ***** ERROR ***** cause = First parameter must either be an object or the name of an existing class
2016-12-19 11:12:12.309 ***** ERROR ***** securityGetAccessRightYesNo : '' is not an existing object class
2016-12-19 11:12:12.309 ***** ERROR ***** securityGetAccessRightYesNo(menu, update, Ticket #, )
2016-12-19 11:12:12.310 ***** ERROR ***** ERROR *****
2016-12-19 11:12:12.310 ***** ERROR ***** on file '/var/www/projeqtor/tool/projeqtor.php' at line (1606)
2016-12-19 11:12:12.310 ***** ERROR ***** cause = First parameter must either be an object or the name of an existing class
2016-12-19 11:12:17.716 ***** ERROR ***** securityGetAccessRightYesNo : '' is not an existing object class
2016-12-19 11:12:17.716 ***** ERROR ***** securityGetAccessRightYesNo(menu, update, Ticket #, )
2016-12-19 11:12:17.717 ***** ERROR ***** ERROR *****
2016-12-19 11:12:17.717 ***** ERROR ***** on file '/var/www/projeqtor/tool/projeqtor.php' at line (1606)
2016-12-19 11:12:17.717 ***** ERROR ***** cause = First parameter must either be an object or the name of an existing class
19 Dec 2016 20:33 #2 by babynus
I cannot reproduce the issue with V3.0 of the plugin.
Maybe you should upgrade...
