ProjeQtOr free project management software - Settings default global 6.0.2 - ProjeQtOr
07 Dec 2016 15:30 #1 by chriscool
hello
If I configure the default settings via the web interface !!!
This is not taken into account
example:
I choose the standard projeqtor theme
I create a new user, it connects on the theme projeqtor!
The setting file did not update
My solution is in sql and it works :-) for to projeqtor standard
UPDATE `projeqtor`.`parameter` SET `parameterValue` = 'ProjeQtOr Standard' WHERE `parameter`.`id` = 137;
I am in version 6.0.2
07 Dec 2016 15:38 #2 by babynus
Possibly you just did not save your configuration ;)
07 Dec 2016 17:39 - 07 Dec 2016 17:40 #3 by chriscool
i saved,
but now it's ok for all settings !
strange bug juste after install !!
we can close it
than you for your answer
Last edit: 07 Dec 2016 17:40 by chriscool.
Time to create page: 0.711 seconds
