ProjeQtOr free project management software - [v6.0.1 acceptance review] - reference planning to fix - ProjeQtOr
30 Nov 2016 19:27 #1 by VERGES
In same way of 45° curve , it would be possible to fix the reference planning at T0 of the projet before "today date".
Validated workload shall be fix in the past ...
01 Dec 2016 12:39 #2 by babynus
This is not an issue with 45° grash but with baseline.
Already recorded as Ticket #2405
08 Dec 2016 15:37 #3 by VERGES
[Acceptance review 6.0.3] : Ok . Now is possible to fix a planning in the past. You're right, is not a 45°curve issue but a baseline configuration issue. To fix a planning in the past is possible only if there are not baseline already fix.
