ProjeQtOr free project management software - [v6.0.1 acceptance review] - impossible to export pdf planning - ProjeQtOr
30 Nov 2016 18:52 #1 by VERGES
when we try to export a pdf planning from "planning view" or "tableau de bord" view, is impossible
30 Nov 2016 19:42 #2 by babynus
Do you mean click on "Export to PDF" button on Planning screen ?
1) Which browser are you using
2) Can you describe what you get ? Do you have a pop-up to select some parameters ? What do you select ? What do you get ?
3) Do you have any error in Browser console ?
4) Can youtry on Chrome ? Do you reproduce issue ?
I don't understand the use case. Coul you detail ?
Are you in menu "Rapports" > "Tableau de bord" and you try to export one of the three reports ?
30 Nov 2016 20:41 #3 by VERGES
I use firefox
Attached the message...
I don't have the issue with chrome....even there is the possibility to export with specific mode "porrtait or landscape ....no the opportunity of export to firefox ...
With the "planning gantt " report in "planning" (report view) on firefox, there is the issue
30 Nov 2016 20:44 #4 by VERGES
With the "planning gantt " report in "planning" (report view) on chrome , there is also the issue
01 Dec 2016 14:06 #5 by babynus
Recorded as Ticket #2411
05 Dec 2016 15:54 #6 by babynus
After some investigation, it seems it is possibly an "out of memory" error.
PDF generation is much "memory" consuming.
So you should act on 2 points :
1) in ProjeQtOr global parameters, increase value for "memory to generate PDF". Try at least value of 512.
2) Check in your php.ini file and try and increase memory_limit (try and set it to 512M)
