ProjeQtOr free project management software - [v6.0.1 acceptance review] - General lack of performance - ProjeQtOr
30 Nov 2016 18:36 #1 by VERGES
With the new version v6.0.1, the tool is less powerfull.
There are some slow-down using it....
30 Nov 2016 18:48 #2 by babynus
Could you please explain ?
When do you get "slow down" ?
Can you give measures ? (before / after)
Please give more detail so that we can get hints.
30 Nov 2016 19:11 #3 by VERGES
Example : when mail is sent for the first time when we assigne a ressource
30 Nov 2016 19:17 #4 by babynus
Maybe it is an issue with your email server, or just connection to it.
As long as I can remember, there is no change in V6.0 about emailing.
01 Dec 2016 10:24 #5 by scorbe
Yes, Pascal, I think we have a problem about RARP about the email server.
Anyway, I confirm that the product is slower than before.
It's difficult to have measures but each user here said me that too.
01 Dec 2016 14:11 #6 by babynus
Could you give more details of what seems to be less performant :
- list of items ?
- display of single item ?
- save of single item ?
- displayh of planning Gantt view ?
Could you :
- check for log file to see if there are errors or unexpected logging lines
- try and disable email generation to try and see if performance is back
